Re: Govenor FarmAll H
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red on February 27, 2000 at 13:20:25 from (12.75.47.20):
In Reply to: Govenor FarmAll H posted by IKE on February 27, 2000 at 12:28:21:
Ike remove the spring and check the thruster bearing behind it. It should slide horizontally on the shaft but should not wiggle while sliding. If it does, then that assembly is worn.
I'll send you a digital picture how the governor should look in the high speed setting.
Post A Followup
: Re: Re: Govenor FarmAll H
