Re: Super A axel shaft stuck
Posted by banjo on January 17, 2008 at 20:33:31 from (65.67.203.17):
In Reply to: Super A axel shaft stuck posted by JerryB4 on January 17, 2008 at 17:15:03:
if your trying to remove the differential shaft the final drive has to come off first. then you have to remove the brake drum before the shaft will come out.
the lower axle shaft is probably being bound up by the heavy bull gear. you shouldnt need to remove it.
