If the history is unknown or if you suspect water in the lines, I'd recommend changing out the fluid, removing the reservoir cover (the big casting the seat bolts to) and cleaning the filter screen. Good time to disconnect and blow out all the lines, too. When you start it up again, just use a little air pressure (about 5 psi) into the reservoir vent to get it to prime.
One caution, the reservoir cover, though not that awful heavy, is cumbersome to lift, and the screen mounts to it and hangs down so that you shouldn't sit it on it's bottom edge. Probably best to use a hoist of some sort to remove it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
