Re: Changing Hydraulic Fluid in a 656
Posted by skyharborcowboy on January 18, 2008 at 13:05:58 from (75.211.54.85):
In Reply to: Changing Hydraulic Fluid in a 656 posted by skyharborcowboy on January 18, 2008 at 07:57:07:
I got 8 gallons out of the differential Case.
The middle plug snapped off the square drive
The front plug requires a 5/16th internal square drive (never even heard of one of those before!
I cannot understand gorilla mechanics. The rear diff drain bolt I had a ratchet and a 5' breaker bar pulling with everything I had before it would even budge!!!!!!!!!!!!!!!!!!!!!!!!!!
I am going to go hunting for a 5/16 square drive now. The other plug is in there for life! It snapped clean off and there is no easy out that is going to get that out as tight as the last monkey put it in there!
Joe
