Re: 656 Farmall Gas
Posted by Jerry Gilliam on January 19, 2008 at 14:39:45 from (72.155.213.135):
In Reply to: Re: 656 Farmall Gas posted by TractormanNC on January 19, 2008 at 13:42:09:
Thanks for the reply. But that's were I noticed there was no fitting. My 460 has the grease fitting directly attached to the greaser around the bearing itself. The book shows a grease fitting in the casted part that pushes the throw out bearing, but I can't see it. Jerry
