300 Utility Hydraulic Pump Surging
Posted by LarryD on January 20, 2008 at 06:52:56 from (207.224.111.109):
I've noticed recently that my hydraulic pump kind of surges and slows down the engine. This is happening now pretty close to every second now. The pump is for the three point and a one way hose coupler.
I did find the resevoir low on oil and brought it back up but it's still doing it. I also had some leakage at the pump and found some bolts loose, so tightened them back up.
Does anyone have any suggestions as to what to check or how to fix the problem?
