Re: M with antifreeze in oil
Posted by old on January 20, 2008 at 09:56:19 from (4.244.90.226):
In Reply to: M with antifreeze in oil posted by 1 Dollar on January 20, 2008 at 09:33:55:
Does it run?? If it does run then I would warm it up and then torque the head bolts when its warm. If you find any of them loose then you probably have found the problem. If none are loose then its probably a bad head gasket. But yes it could be a cracked head or other things also
