Re: 856/656 Utility
Posted by Chuck46 on January 20, 2008 at 13:54:21 from (64.136.27.229):
In Reply to: 856/656 Utility posted by Daniel Bear Kelley on January 20, 2008 at 07:50:55:
Daniel, I remember your first post, a utility will have a lower profile with probably 30 inch rear wheels instead of 34 or 38. The front axle will be set back for a shorter wheel base. the seat is lower so the driver will stradle the transmission. Rear axles are non ajustable so the width is changed by rim configuration. The 656 is the largest utility I know. A 574, 674, 584 or 684 might be worth considering also.
