Re: 656 Wide Front End
Posted by Allan In NE on January 20, 2008 at 18:46:34 from (148.78.243.25):
In Reply to: Re: 656 Wide Front End posted by jeffnc on January 20, 2008 at 18:31:47:
Just about any way you can make it work.
Those badly stuck ones, I use pure brute power and pull 'em apart with two other tractors.
Lessor stuck units, a man can get away with penetrating oil, heat and a big hammer.
Heard of fellas loosening the bolts and driving them around for a week with just the pins holding the pipes. The "jarring" seems to help break 'em loose.
Once they are loose tho, I really grease and lube 'em up so it won't happen again.
Allan
