Re: F12 CAMSHAFT
Posted by teddy52food on January 21, 2008 at 06:44:18 from (209.237.111.169):
In Reply to: F12 CAMSHAFT posted by kam on January 21, 2008 at 03:08:25:
Check the cam lobes to see if they are ready to fire at TDC (both valves closed). I am not sure on an F12 but on a B when the marks are lined up it is ready to fire on # 4.
