Re: F12 CAMSHAFT
Posted by El Toro on January 21, 2008 at 07:38:23 from (205.188.116.73):
In Reply to: F12 CAMSHAFT posted by kam on January 21, 2008 at 03:08:25:
Try this Ted, Mesh the single punch mark on the camgear with the double punch marks on crankshaft gear. Mesh the double punch marks on the camshaft gear with the double punch marks on the magneto-governor or distributor drive gear. Your woodruff key on the camgear should face to your left. Hal
