Re: H Rear axle bearing question
Posted by Gauger on January 21, 2008 at 12:23:51 from (4.159.168.30):
In Reply to: H Rear axle bearing question posted by neblinc on January 21, 2008 at 10:50:10:
I think the shielded side should face the differential housing. The oil from the rear end does not reach the outer bearing and you will not get any lube to the bearing through the shield. I believe the shielded side is meant to keep the axle housing from filling up with grease.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
