Re: H Rear axle bearing question
Posted by Randy in NE on January 21, 2008 at 12:24:16 from (204.124.192.32):
In Reply to: H Rear axle bearing question posted by neblinc on January 21, 2008 at 10:50:10:
I had to get a sealed bearing when I replaced the bearing on the input shaft to the transmission. I just pealed away the metal seal and let it get lubricated by the transmission grease. This should work also.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
