Posted by BillfromIL on January 21, 2008 at 21:13:09 from (206.71.203.188):
In Reply to: 436 problems posted by bustedbudget on January 21, 2008 at 19:10:51:
Check for air restrictions, filter collasped, hoses, ect. Also check for restrictions in the fuel delivery system. If she can't get enough fuel, she'll struggle starting and loss of power. Learned along time ago, IH fuel filters will have more power on a dyno test than most aftermarket filters. Cost me a sevice call and getting my tractor to the shop, paying them to tell me my new aftermarket filters were restrictive by 20 hp. Put a guage on the intake manifold behind the turbo and see if you have any boost pressure. If not, turbo bad. Then pull injectors and do a compression check, check injectors while they are out. Then pull pump and have it checked. Somewhere along the line pull the valve cover and check clearances. This is then approach I'd take. you'll find it somewhere along the search.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
