Re: Rollover Plow
Posted by Leon MN on January 22, 2008 at 06:15:36 from (74.47.82.162):
In Reply to: Rollover Plow posted by RockyMO on January 22, 2008 at 04:44:24:
I have a simular plow. In this part of the world it would be called a trip plow, due to the desgin where you pull the rope to trip the left wheel allowing it to rise, lowering the plow into the dirt. Pull the rope again at the end of the field to raise the plow.
As for where the spring connects, there should be a sort of trip relese on the hitch where it connects to a tractor (usually with a twisted clevis) so when you hit a rock it will release and not break the plow. The rope should have some kind of clip so it will release too, a string that breaks will work.
Any tires will work as they are for transport only. The right tire will be in the furrow when plowing. The left will ride on the surface when plowing but not as a guage wheel.
Look at hte castings for some kind of clues to identify the brand.
