I think you will need to remove the bolster to get the front shaft out. At least on the H you do. The whole gizmo comes out the rear of the bolster. The flanged sheet metal collar is held in place by a big coil spring on the outside of the starter and you slide the collar to the rear compressing the spring to remove the pin. ken
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
