Water will raise up the oil level for sure. My Steamboat has what is called a displacement oiler and uses condensed water to raise the level of oil so it can run out and lube the inside the steam cylinder. Your tractor rear end is the same. water raised up the level and it is leaking out at a point higher than it should. Let it sit for a few days and drain out what is in the bottom. Don"t forget the front plug if Cs are like Hs and have 2 drains.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
