Re: M distributor does not turn
Posted by mkirsch on January 22, 2008 at 09:50:27 from (64.80.108.52):
In Reply to: M distributor does not turn posted by the Unforgiven on January 21, 2008 at 18:43:55:
If it's an IH hydraulic pump, the keyway on the drive gear probably sheared. It happened on Dad's Super M several times, usually when shaking the manure off the end gate of the spreader. Either he was running the belly pump reservoir dry with the gate all the way up, or the shock load of the gate bouncing up and down was too much.
I remember one time, he had a part of a load on when it sheared. He just wrapped a chain on the front axle, engaged the PTO, put it in 3rd, and had me tow him around the field! Ground driven spreader :)
