Re: Wiring of Voltage regulator
Posted by Janicholson on January 23, 2008 at 06:05:48 from (199.17.6.122):
In Reply to: Wiring of Voltage regulator posted by Mifsud on January 22, 2008 at 16:53:57:
Glennster is correct, the light switch in conjunction with the operator is the "voltasge regulator" If the charging system is working, and you are regulating the charge with H and L on the switch, there is no problem. If you want to make it more regulated and automatic, or it is not charging, there are many well worded contributions from John T, Bob M, auself, and others that address the why. Use the search for box to find them. Put in cutout relay. Or put in Converting to Voltage regulator, or LHDB light switch. These searches will do it. JimN
