584 power beyond cover
Posted by Jason M on January 23, 2008 at 08:33:56 from (74.189.99.26):
I went through the Case-IH parts catalogs on their website and found that early power beyond covers for the 584 (part no. 123082C1) had a supply port, and you plumbed the return to the large plug under the right rear axle. Later versions of the cover (part no. 123082C2, which replaced the C1) had a supply and return port in the cover. On the 584, is the return port in the later cover usable, or must you still plumb back to below the rear axle?
Thanks,
Jason M
