Re: X1 for gasoline
Posted by Andrew Z on January 23, 2008 at 11:52:16 from (12.76.144.80):
In Reply to: X1 for gasoline posted by JohnG(TX) on January 23, 2008 at 11:09:25:
Just to add what Rusty said.. The first gas only tractors that came out in prior to june of 40 had a lower compression gas engine then say the latter gas engines in the line.
Andrew
