Re: Farmall H engine dies when let clutvch out
Posted by glennster on January 23, 2008 at 13:17:32 from (76.224.13.122):
In Reply to: Farmall H engine dies when let clutvch out posted by Larry Batson on January 23, 2008 at 12:32:27:
sounds like you got it stuck in two gears. withe the clutch in see if you can roll the tractor (engine off) if it acts like the brakes are locked on, its stuck in two gears. pull the shifter, reach down in the hole with a screwdriver and line the shift rods back up.
