Re: Farmall H engine dies when let clutvch out
Posted by old on January 23, 2008 at 14:49:43 from (4.244.6.8):
In Reply to: Farmall H engine dies when let clutvch out posted by Larry Batson on January 23, 2008 at 12:32:27:
First off. Will it start back up if you hold the clutch pedal down?? Then if you take it out of gear both the transmission and PTO will it keep run if you let up on the clutch or does it die again. If it dies most likely stuck in 2 gears but if it keeps running then probably a carb or fuel system problem
