Re: Negative Ground?
Posted by DanJ13655 on January 24, 2008 at 04:54:38 from (65.28.230.221):
In Reply to: Re: Negative Ground? posted by gene bender on January 24, 2008 at 04:45:59:
Thanks -- I never thought about the regulator -- I know little about the regulator. The battery will not even charge up, and the tractor doesn't turn over (OK, maybe just a tiny bit) when I have the charger on it, on the "Engine Start" mode. The starter's good (I bench tested it). So, you're saying that I can make a positive ground if the regulator is a positive ground regulator?
