Re: Negative Ground?
Posted by DanJ13655 on January 24, 2008 at 13:00:51 from (65.28.230.221):
In Reply to: Re: Negative Ground? posted by Janicholson on January 24, 2008 at 06:22:56:
Thanks, I'll give this a try in a few minutes. The battery is absolutely dead -- my buddies at Advanced Auto Parts confirmed it for me. I'll also change it back to a positive ground, and will check the coil, voltage regulator and generator. No, to answer one of the questions you guys posed, it has not been changed to a 12-volt system. But if this gives me much more trouble, it sure as h*ll will!
