Re: Negative Ground Part III - another question
Posted by Tom43 on January 25, 2008 at 05:10:42 from (64.149.38.158):
In Reply to: Negative Ground Part III - another question posted by DanJ13655 on January 25, 2008 at 04:59:15:
That is too much voltage. If allowed to continue, you will boil your battery dry and burn your ignition points with the extra current flow forced through them with the high voltage. you should be looking at around 7.3 volts for a charged battery.
