Re: Negative Ground Part III - another question
Posted by Tom43 on January 25, 2008 at 11:03:47 from (64.149.38.158):
In Reply to: Negative Ground Part III - another question posted by DanJ13655 on January 25, 2008 at 04:59:15:
My experience with 8 volt batteries is very negative. Pun intended. Eight volt batteries are hard on the whole electrical system outside of the starter. The extra voltage which must be boosted to around 9.5 to 10 will put enough extra current through ignition points to burn them. The extra current through both the cut out relay and voltage regulator will send that unit to an early grave also.
