Re: 656 FARMALL GAS 263 CID 1966 yr
Posted by Jerry Gilliam on January 25, 2008 at 13:06:28 from (65.4.211.178):
In Reply to: Re: 656 FARMALL GAS 263 CID 1966 yr posted by Allan In NE on January 25, 2008 at 12:19:39:
Good Point. But I can determine that later if I could find a IH small gauge that will work. The one on my 460 has white, green, red in colors with the IH symbol. I may not use it, but if it won't work, then there is no reason to even persue the issue. I am not sure if the 460 has something like a certain type sending unit that I would have to buy, etc, etc. I was also told that the OEM gauge had a mercury sending cabel and if the tractor was tore apart and someone broke the line, that's all she wrote.
Jerry
