Re: Guages - Ammeter or voltage
Posted by ScottyHOMEy on January 25, 2008 at 13:14:51 from (71.241.213.254):
In Reply to: Guages - Ammeter or voltage posted by bc on January 25, 2008 at 12:58:30:
I sometimes think it would be nice to have both! Helps to chase down gremlins whne they've been busy.
That said, the ammeter will wire in directly and does give you useful info as long as you check it periodically. Does the tractopr seem to charge okay otherwise? If so I'd say just replace the ammeter.
As for the volt meter, I may be washed up on this, but I suspect you'll have to rework your wiring a) for it to work right and b) to make sure it doesn't affect the functioning of your voltage regulator.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
