Re: Guages - Ammeter or voltage
Posted by Bus Driver on January 25, 2008 at 17:00:33 from (66.44.251.47):
In Reply to: Guages - Ammeter or voltage posted by bc on January 25, 2008 at 12:58:30:
A voltmeter must be disconnected when the engine is not running. If left connected, it will slowly drain the battery. So some wiring changes would be necessary.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
