55 50; I have a friend that had one serial # 1050 ? or so, we redone. I looked at the back side of it alot. There are three styles of front assy. for f-20's. This type is the early only made in 1932 and 1933. The other two styles have a finial atop the front casting easy to spot from the rear veiw like this. If you look the the web site photo it's easier to see it. There is foot stops cast into to rear housing, top exhaust, so its not a Regular Farmall. Wrong hubs and axles to be a f-30. You can make out the f-20 decal on the gas tank.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
