Re: Farmall H lift-all system?
Posted by scott rukke on January 25, 2008 at 20:03:10 from (67.183.230.71):
In Reply to: Farmall H lift-all system? posted by J Rotunda on January 25, 2008 at 18:48:20:
third party image
Here is a schematic for the liftall if you want power up and power down. You can email me at srukke@comcast.net if you want a scan of the owners manual and how it works. There are different ports on the system and one is a delayed port. I highly recommend that you plumb the return line into the bottom of the tank rather than the filler tube. The oil may foam up if plumbed to the filler. I put a tee where my drain plug was and plumbed the return in onmazingly the system uses 30w motor oil. You can use hydraulic oil but it is designed to use motor oil.
