Posted by skyharborcowboy on January 25, 2008 at 20:56:07 from (75.210.5.150):
In Reply to: ran over posted by TX. Bulldog on January 25, 2008 at 20:13:13:
One other thought is that maybe the clutch is set up with not enough free play that allowed the clutch to drag spinning the transmission main shaft and the shift forks were just close enough to engage whichever gear it went into. In addition, it might be a good idea to make sure the brakes are set when starting the tractor next time.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
