Re: Farmall H lift-all system?
Posted by akb on January 25, 2008 at 23:03:22 from (75.161.132.24):
In Reply to: Re: Farmall H lift-all system? posted by Janicholson on January 25, 2008 at 20:38:30:
You have to plumb the pressure out to the bottom of the belly pump use a tee fitting in the drain hole if you go into the top vent pipe it will foam and blow out even with a 3 foot extention.
