Posted by spanky on January 26, 2008 at 05:13:25 from (216.93.96.50):
In Reply to: ran over posted by TX. Bulldog on January 25, 2008 at 20:13:13:
A few years ago I was working on my Gleaner F2 and while I was on the right side of it I must have touched a shift rod just right. It went into 3rd gear and was off like a shot. Fortunately it was idling and the variable drive was in a slower position. I was able to run after it climb aboard and stop it with in inches of a tree. It never ground a gear, just popped in and off it went. I didn't know I could run that fast still.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
