Re: lock out the T/A on 1963 Farmall 460
Posted by Lynn Davis on January 26, 2008 at 09:15:14 from (88.202.52.8):
In Reply to: lock out the T/A on 1963 Farmall 460 posted by blindcowboy on January 25, 2008 at 21:34:27:
Yes, it can be adjusted. I can not recall the measurements and I not able to look them up, my books are not in the same country as I am. I will give you a rough est. I'm sure some one can correct but this should work. Disconnect link from TA to clutch, adjust clutch free travel 15/16", rotate TA crank arm so that throwout bearing of TA is contacting,adjust link from clutch crank to TA crank so that pin will just fit,I think it should be tightened a little more, 1/8", or one turn? But this should give a starting place until you get better info. I often have had to pull the TA back to shift out of gear when in a tight spot.
