Posted by Farmall Farris on January 26, 2008 at 09:37:14 from (75.90.142.224):
In Reply to: ran over posted by TX. Bulldog on January 25, 2008 at 20:13:13:
When I was a teenager, I worked for the local Case IH dealership. A guy had brought in a IH 544 and I was told to fill his rear tires with calcium cloride. I did the usual, I pulled around to the side of the building and I thought I had the valve stem in the upper most position. I killed the tractor and jumped off. After setting up the calcium pump I realized that the tire needed to move back another 18 inches or so. Me being young and dumb, standing on the ground, I put the tractor in reverse gear and was going to use the starter to bump the tractor back. I thought the fuel shutoff was out but I was wrong! As soon as I hit the starter it fired up and completely ran over a new Cub Cadet lawnmower before I could shut it off. I was not only lucky not to get fired but I escaped injury as well. From that day forward I have never started a tractor from the ground or left one running without me on the seat. I have always wondered why the engineers didnt put a PARK gate in the tranny.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
