Posted by CNKS on January 26, 2008 at 19:01:00 from (216.144.104.128):
In Reply to: ran over posted by TX. Bulldog on January 25, 2008 at 20:13:13:
On the early H (not the SH)and any other letter series, electric starting was an option. You stood in front of the tractor and cranked it, I have done that hundreds of times. I was told at an early age to make sure it is in neutral. I commonly start my electric start tractors from the ground and let them idle anywhere from a few seconds to a few minutes, depending on the weather. It is HARD (read impossible) to get an IH tractor into gear with the clutch engaged. You have something out of adjustment. You say you had everything apart. Did you put the springs back in the shift mechanism, if I remember right there are "poppet" springs and balls that put tension on the shift lever, without them the lever is loose, and the position of the lever is vague at best. It could have been partially in gear when started and perhaps vibrated into gear. In my mind, unless the parts are severely worn, it is impossible for it to shift gears by itself.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
