Re: farmall b head gasket
Posted by Red Dave on January 27, 2008 at 07:53:19 from (68.44.136.10):
In Reply to: farmall b head gasket posted by alpo on January 26, 2008 at 17:35:18:
These head gaskets need sealer used on them, did you use it? 85 ft lbs is 5 more than is called for.
Did you torque the head using the pattern called for in the manual? It is also important because it keeps the head pulled down evenly.
If you used the sealer, get it running and re-torque after it runs long enough to get up to operating temperature, that may be all it needs.
