Re: 806 Steering, Brakes, and T/A
Posted by Lynn Davis on January 28, 2008 at 09:02:35 from (88.202.52.8):
In Reply to: Re: 806 Steering, Brakes, and T/A posted by mhalter on January 28, 2008 at 06:31:39:
Probably only one "problem" low pressure caused by any of the above. Remotes, hitch, and PTO operate independantly. Steering,brakes, and TA operate off same pump. A bad pump, or internal leak will cause a short supply when using more than one function. Operating at low pressure will eat the TA clutches in minutes BTDT, not ment to slip.
