I've seen the plug come out of an engine one time. Luckily the detroit diesel had an automatic shut down that shut it down when the psi went down.
The oil will tell you if you have a cracked head or block with water getting into the oil. With tractor, a bad seal could cause hy-tran to run over into the oil. I learned a new one here with the bad carb needle valve letting gas into it. I've been fighting carb problems and I've noticed that my oil level might have come up a little and thinned out but not enough to worry about but I will change it anyway.
Also engines just flat use oil. It doesn't have to be a smoker to do so. My 5.4l ford pu uses a quart each oil change and it is not burning it or leaking it.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
