Re: C-263-points, plug wires, plugs questions
Posted by Janicholson on January 29, 2008 at 09:09:33 from (199.17.6.122):
In Reply to: C-263-points, plug wires, plugs questions posted by bc on January 29, 2008 at 08:48:42:
I say you are in great shape.
The points often have that issue. try adjusting them when they are just able to be moved, it helps in the process of final gap.
The tank issue seems fine. Ido not know if you have rubber hose, but I use only steel line for safety on a gravity feed carb. Just my belief.
The plug wire terminals can touch anything but a hot manifold, (those are on the other side) sharp edges will wear through and need to be eliminated. Open the copper clips in the cap tower end of the wires to see if they can get a better grip. The boots should also hold some. Make sure there is no material left in the cap from the old wire ends. There is a neat tool to clean them KD brand has it and many others.
I would read the new plugs after 20 hours of operation to check them against the old. the best info is consistancy, and bad wires/etc. can fowl plugs as much as rings. Keep us infoprmed on its reality. JimN
