Re: h points
Posted by riverbend on January 29, 2008 at 15:14:18 from (208.160.33.55):
In Reply to: h points posted by GI FARMER on January 29, 2008 at 10:50:26:
I still have points in my H. The problem I had was that the points weren't lasting very long. Adding a second condensor fixed that. Now they last 2-3 years, and I use my H pretty regularly.
The electronic ignitions are reliable, and I think they are a little more forgiving of worn bushings in the distributor. However, I know that I can fix the points/coil set up in the field.
Greg
