Posted by Dave Allgire on January 30, 2008 at 08:24:13 from (24.217.155.142):
In Reply to: F12 REAR SEAl posted by kam on January 29, 2008 at 19:49:02:
You have to leave the seals at their correct length. Yeah, its a little bit of a pain to get them squeezed in. There is a gasket that goes between the upper and lower halves. It is part #24426-D and available from Rice Equipment. I've found if you tighten the two bolts that pull the two halves together, you will have better luck getting the three bolts that hold the top half to the block to go in easier.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
