Re: C-263-points, plug wires, plugs questions
Posted by bc on January 30, 2008 at 09:35:15 from (208.190.253.101):
In Reply to: C-263-points, plug wires, plugs questions posted by bc on January 29, 2008 at 08:48:42:
Another update. After changing the coil, plugs, plug wires, points, condenser, and R&R the carb, I was able to run around the pasture up and down hill moving a few bales with no bog downs. Happy days I hope. In fact, this summer I had dug a 4 foot deep hole and placed a 9" diameter section of old telephone pole in there for a snubbing post to tie my mustangs to(one that they can't pull over). Anyway I went driving up the corral in the dark with a bale on the front slow in low gear while getting ready to set the bale down. I forgot about the post and about the time I looked to where I thought it should be, I heard a crack and the motor didn't hardly pull down at all in breaking that post off. The pole had a bad place on it about ground level but I thought it should have stalled out the tractor a little.
Thanks to all for your help.
Anyway now I can concentrate on fixing the hydraulics and the steering. I've been riding it around without a seat cause I'm trying to take that plate off under the seat to trouble shoot the hydraulics. There is one bolt head left that was so messed up I can't get vise grips to hold. I'm just waiting to take a welder out there or maybe more easily just take the torch and braze a nut to it. Once that cover is off, then I'll start a new thread about what to look for and where is the psi relief valve in there that could possibly be plugged up.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
