Posted by Flinn on January 30, 2008 at 12:29:06 from (207.200.116.7):
Have the head off the Cub so I want to adjust the valves. Serice Manual says to put #1 piston (one at front of radiator) at TDC. Then adjust the valves in order of 1,2,3,5. When I look at this some of the valves are adjusted in the open position and some are closed. Is this correct? The valves under #1 piston (the 1 and # 2 valve) are both closed. 3rd valve is open as is #5 valve.Is this correct way to adjust them. Then it says to bring the #4 piston (one closes to driver) to top and adjust the 4,6,7, and 8 valves. Are the valve #s counted from the front of the motor to the rear? Any help appreciate. Also some say 13 ths. and some 15 ths. Which one?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
