Re: Electrical Question ---- Bob Melvins
Posted by gene bender on January 30, 2008 at 18:15:05 from (67.55.226.214):
In Reply to: Electrical Question ---- Bob Melvins posted by Mifsud on January 30, 2008 at 17:44:49:
You need to replace the sw with one that has two posts the wire you now have goes to the sw and other post a wire needs battery voltage. The cut-out needs no change. This will put 6v to the coil and you will use the same wire now grounding out the mag.They usually run 6v on the side from the gen to the ammeter this way the ammeter will show discharge when the sw is on.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
