Re: Swartz Wide front Qeustions?
Posted by MN Scott on January 30, 2008 at 20:20:24 from (206.9.216.44):
In Reply to: Re: Swartz Wide front Qeustions? posted by IaGary on January 30, 2008 at 18:01:33:
This one is built different than Allan's. It has angle irons for a frame and the rear wishbone pivot mounts are incorporated in that frame and there are no holes drilled in the tractor frame rails. If I remember there are holes drilled at different centers as if it will fit other tractor models to. I know they bought it so they could swath oats with the Deere no. 5 mower for their first pull type combine a IHC 82. They would put it on at swathing time and it would stay on to cultivating time next spring. It does crank the arms all the way to the stops so turning is not affected. I know it turns sharper and with less effort than the factory 54 does.
