Re: flare box capacity
Posted by gene bender on January 31, 2008 at 04:17:09 from (67.55.226.214):
In Reply to: flare box capacity posted by sgt bull on January 30, 2008 at 13:51:44:
You say old that opens up a big story as there were so many different sizzes of the old flare boxes. Some were steel,galvanized then wood then added on to the old horse wagons. The only way to know about yours is measure. These posts are getting flare boxes all mixed. When you said old they held around 60-70 it took a barge box to hold 100. Some still sell around here even some with hoists.
