Re: Springtooth grass seed drill size for a tractor -656/26
Posted by Janicholson on January 31, 2008 at 06:41:04 from (199.17.6.122):
In Reply to: Springtooth grass seed drill size for a tractor -656/2656/6 posted by bc on January 30, 2008 at 08:59:10:
The tractor could pull a springtooth harrow of 20' width. (assuming the hoe was taken off etc). The spring tooth pulls pretty easy and is only limited by reasonable size on smaller plots.
Discuss grass seeding with your extension agent. Things are so different across even one county/and soil type that general info is marginal.
On the Drill, The shoes, listers or sweeps that open the seed depth may be worn rusted or trashed. Seed drop tubes and gear drives for agitators and measuring flow rates can also be frozen. If it is 20 years in the same spot, it may take a phenominal amount of work to make it operational. JimN
